Krimlin »
https://forums.nicoclub.com/krimlin-u105213.html
Mon Mar 29, 2010 5:08 pm
Well I'm seeing if you guys can help.
I have a 95 Nissan 240sx with a 95 VH45de from a Q45 swapped in, everything is working on the car but it's not getting any spark. We've checked it, it's getting power to the fuse block from the ECU but from there to the spark plugs nothing's happening, fuses arn't blown and volts check normal.
Edit* - Also tried the 94 ECU and a 92 ECU both seem to work fine but no spark. Also on first attempt to start it had a weak spark and a little bit of fire came out of the heads, but now it gets nothing.
95 stock VH45deStock uncut wiring harnessMazworx jumper harness (Plugs the ecu to the chassis harness)
If anyone has a wiring diagram that would help too!
Modified by Krimlin at 8:20 PM 3/29/2010
