MinnyQ »
https://forums.nicoclub.com/minnyq-u362.html
Tue Nov 13, 2007 9:14 am
I wrote in a couple months ago about a fluttering/hesitating thing on my '95. Original transmission. Now 272k. The dealer said it was the torque converter and pretty much declared it dead. I took to a transmission shop for a second opinion. They doubted it was the TC (as did several of you guys), checked the fluid, declared it "very good", (flushes every 20k). But then the problem went away. A couple of you here mentioned external electrical connections underneath, roughly under the front seats. So ... I had the thing up on a hoist and sure enough there is a thoroughly exposed box with a half dozen electrical connectors, some with exposed multi-color wires. This doesn't look eight. I'm assuming this used to have a cover ... or something.
What is this? Is there a part (cover) missing? What's your recommendation?
Since the hesitancy/fluttering occurred after a three hour drive in steady rain, my guess is that this could have something to do with it.
