'95 transmission problem
aus_max95
Car: '95 Maxima
Hey guys im noticin more and more that when i take off every now and then the car stays in first for too long and revs too high before dropping to second. I just think its an issue because the whole car heavily jolts when it changes gears. It doesnt happen in any other gear so i was wondering if anyone knew what could be the problem. Would i be able to fix it or have to take it to the mechanic?
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
First thing I'd do is check fluid level and quality.
NutriaforBreakfast
Car: Nissan Maxima 1995 VQDE engine
Open a quart of new transmission fluid and smell it then
Check you transmission dipstick and smell the fluid
If your transmission fluid smells burned compared to the new quart youprobably need to change your pan fluid and filter
Also look at the color. If its not red like the new quartthen you probably need to change the pan fluid and filter
You might want to consider changing the torque converter fluidtoo if the pan fluid and filter change dont help
