First things first...I know more about my 240sx coupe than I do my girlfriend's automatic 95 Sentra with a ga16de engine.
I believe she is experiencing some problems with the EGR valve if not some where within the system.....however I am not exactly sure.
Here is what I know so far...based on what she has told me.1. Check engine light comes on when the a/c is turned on and going in reverse.2. Feels clunky3. The engine is slow and stumbles as if it is going to stall when slowing down or coming to a stop.
I am guessing the egr system or valve because of the idle stumbling.I am not sure what to think about the a/c, reverse, check engine light.
Furthermore, she tells me and I have noticed the check engine light turning on and off seemingly at random. The a/c, reverse, check engine light....occurrence happens semi regularly and I have known about it for a while now. We have not done anything about it because she usually has the a/c off when she starts the car until she gets up to speed on the highway.
Also....the last time it was in the shop we had a transmission leak fixed and the MAF sensor replaced. When she was doing a lot of daily driving, for work, I installed a K&N OEM replacement air filter into her car. I am not sure when the spark plugs where changed and I would not doubt it is time to change them.
If anyone has any information that could shed some light on the situation the help would be appreciated.
