pmkls2 »
https://forums.nicoclub.com/pmkls2-u8760.html
Sat Jan 13, 2007 9:54 am
I checked the ecm and got a code 76 which was a fuel injection system fault. I removed the pluge and dried them off, checked the fuel pump again, checked the maf and wiring, rechecked the spark again. And after all that i still found nothing. On a last try I unplugger the coolant temp sensor to look ad the plug for corrosion and just out of curiosity I cranked the engine over and it fired right up. It was flooded from cranking so much and not starting but after letting it run a minute it smoother out and ran ok. I am guessing at this point that the sensor is bad so I am going to put in a new one tomorrow and see how it goes.
