NISTECH »
https://forums.nicoclub.com/nistech-u7581.html
Thu May 20, 2004 7:04 am
before you get to far into this you need to determine if the A/C is infact on. when this problem is occuring look at your compressor while the car is running, Is the middle of the pulley spinning? If its not your A/C is not on. The vents are not blowing refrigerated air and it must be the outside air your feeling blow from the vents. After you do this check if you find it is turning when all the controls are shut off post back and I will post what you need to check inside the car after you do the relay pulling test I mentioned above. I have looked at the wiring diagram and found this system primarily is operated by the ECM. This does not mean the ECM is the failure so dont run out and buy one. if its failing it would likely be the thermal control amp or the push button control unit.
