95 s14 power window???help
nismo_power
Car: 91 240sx fastback se
ok so my power window on my 95 s14 died...just the driver side...i tested the window switch and amp on a friends car and it works fine...so im guessing its the motor...
1. what other car uses the same window motor as a 95 s14 that i can get from the local pick a part...or will i have to get a s14 one???
2. the window is rolled down and i cant get it to go up or can i get it up some way?? do i need to remove the whole window and brackets to get to the window motor??
DustyS13
Car: 1992 s13 Coupe
not trying to be a d!ck, but a search will more than likely bring this up.
numbnuts240
1974 Datsun Fairlady-Z 250GT
2011 Ford Focus
2010 Mazda 3
i forget the year, but the rear window motors from a maxima will work. probably from an altima as well. find some similar year nissans in the yard and start pulling motors to compare.
you can get to the motor once the panel is off. just remove the motor and lift the window up. wedge a piece of wood in there to keep the window up or reinstall the motor and it will hold.
nismo_power
so how do i get the window to go up so that i can take the motor out? i looked at it and it looks to me like there are 4 phillup screws holding it on but no room to get a phillups in there with the window right there...
