The previous owner connected a switch for the gauge cluster to come on. It went to a green wire between the engine bay relay/fuse box and the shock tower. I found out the 7.5amp fuse "Meter" was blown after replacing it my gauges worked no problem so I pulled the switch/wires that he had ran. With nothing connected to that green wire *no power to it* the gauges still work. With the key out of the car I ran a power wire from the battery to the green wire *that the switch was hooked to* and the dash lights come on but still no stereo or clock.
I figured I had blown a fuse because I had sparked the switched or constant wire *forget which* when I was messing with the wiring with another deck. For sure tho all fuses inside and out are fine. I'll just loop the switched 12v on my stereo harness to the constant and have no memory on my deck for now, I don't want to run my own constant to the stereo I'd rather fix the problem, plus that would not help with my clock working.
Lend a helping hand NICO!!!!! I don't ask a lot of questions on here because I either search or figure it out through asking friends. I'm alright with wiring but this just has me stumped. PLEASE no LOOK UP THE FSM replies because anyone with a similar issue I found was thrown that answer and I've already looked at it. I'll probably kill myself if I have to retrace that constant wire without any helpful hints.
Thx for any help you can give
Tim
