95 S14 Manual trans will not shift HELP!!!!
S14Juggalo
Car: 95 240sx (S14)
I was told by some retard that my bell housing comes off from the trans and i could bolts the bellhousing to the motor then slide the trans onto the bellhousing EEEEEEHHHHH WRONG! The trans case slide off a little and nothing to my knowledge came out or fell out but when i bolted the trans back together the muther fudger wont shift out of neutral (i put it in neutral before attempting to seperate) the trans is out of the car and nothing attached to the output shaft no throw out bearing or anything it should shift through the gears Did i screw it up or some thing Please Help me Its driving me NUTZ!!!!!
whatvtec
Car: 91 240sx
S14Juggalo wrote:I was told by some retard that my bell housing comes off from the trans and i could bolts the bellhousing to the motor then slide the trans onto the bellhousing EEEEEEHHHHH WRONG! The trans case slide off a little and nothing to my knowledge came out or fell out but when i bolted the trans back together the muther fudger wont shift out of neutral (i put it in neutral before attempting to seperate) the trans is out of the car and nothing attached to the output shaft no throw out bearing or anything it should shift through the gears Did i screw it up or some thing Please Help me Its driving me NUTZ!!!!!
did u check to see if u have fluid in it?
S14Juggalo
Car: 95 240sx (S14)
no there is no fluid in it period cuz it dumped out when i seperated the casing from the plate and bell housing! But i would think it would still shift wouldnt? Its out of the car and not spinning just wanted to make sure it was in neutral and it wouldnt go into any gear at all.
S14Juggalo
Car: 95 240sx (S14)
Anybody have any clues to what the duece is going on with my trans?
r3v_v3ng3
Car: 91 fastback ka-t
hmm.... its should shift through the gears. so if you put the shifter on it won't go through the gears? if not maybe its seized
S14Juggalo
Car: 95 240sx (S14)
r3v_v3ng3 wrote:hmm.... its should shift through the gears. so if you put the shifter on it won't go through the gears? if not maybe its seized
Nope but i got it in now and i got it to go into 1st then back into neutral without oil so i left it at that till i fill it up and see what happens.
S14Juggalo
Car: 95 240sx (S14)
Shes filled up and i only have ONE gears s*** f*** DAMN!!!!! Anyone please help!?!
moso
Car: 89 240sx ka24de 5spd
90 240sx ka24de RIP
you know i searched the whole internet and i ended up here
guess i could have used the search button!
http://www.nicoclub.com/articles.php?id=239220
S14Juggalo
Car: 95 240sx (S14)
Well aint that a biiiiits!!!! I couldve used that along time ago before i tryed my donkey idea! I found out that one of the bearings fell out of the main plate and is the culprit! I havent had time to put it back in yet due to massive rain here. But Thank You very much!
