95 S14 KA24DE PCV Questions
GIJOE69
Car: Going Side Ways!
I just got done from a freggin long & troublesome PCV replacement....freggin had to jack up the car, put on jack stands, remove under engine splash guard, then remove intake pipes & disconnect alternator and remove freggin oil sending unit and then freggin removed the alternator & intake manifold bracket...freggin PCV was a pain in the *** to remove had to use a 19mm ratchet combination wrench also note that freggin pain in the *** to remove the PCV hose which freggin broke in about 1/4" hose from the PCV to the line which I can't find where the hell the PCV lines connect to the block or intake manifold so I had to mickey mouse it using duck tape & a nice durable tube....will a mickey mouse duck tape and tube connector cause any trouble for me? thanks.........
masterbunta
That hose goes to a metal line that has 4 little hoses connected to it, and each one goes to an intake runner.
If the hose leaks, it will be a vaccuum leak, seeing as its connected directly to the intake.
GIJOE69
i did a quick fix didn't want to disassemble to whole intake manfiold and fuel rail so I just bougtha two female 3/8's end and extended the hose....nissan sucks!! so freggin hard just to get the PCV...remove oil filter, move aside the alternator and remove the bracket and barely enough room to get your hands in their oh well december RB25 swap
reezn
Car: 2005 G35C 6mt
I looked for threads like this to help me because I also had to change the PCV, but didn't come across this one until I did the same mistake and tore the PCV hose. I now have a vacuum leak. I thought I could just use a fat clamp to hold the hose together, but I could hear it hiss when I put it backed together so I'm screwed. I was going to take the intake manifold off, but I think I'll just do this 3/8 hose quickie. The problem is that the PCV hose is hard and cracks when you try to bend it to put the PCV Back on. (fixed now).
Modified by reezn at 5:22 PM 12/2/2008
