sil8tdrifter »
https://forums.nicoclub.com/sil8tdrifter-u7503.html
Fri Aug 13, 2004 6:23 am
Thank you NISTECH! :ylsuper It went in like butta! One thing, I didn't see until after installation but in the serv. man. it says to align the notches on the converter to the "holes" along the outside of the input shaft.These holes would be the fluid path from tran. to converter. I didn't do this but the damn thing bolted up.Everything is back on the car tran/driveshaft,Exh. ...etc. Well, I started it up and shifted the tran from P, R, N, D, 1, 2.With the brake on I gave a little gas while in each gear.Nothing, absolutely nada. Just like before I started with the Old tran. There is no feeling of the tran. shifting with each shift in the gears. I filled the fluid up before the test, so I don't think that's the problem. I'm not sure... I just bagged it up came home and took a friggen shower. Any Ideas? Thanks.
