NISTECH »
https://forums.nicoclub.com/nistech-u7581.html
Sun Jul 03, 2005 6:48 am
Its a peice of cake to replace. If you look up at the heater box from the passenger floor board you will see a 4 pin flat connector. That connector is plugged into the "Blower resistor". There are 2 phillips head screw holding it in. Simply remove those 2 screws and pull it out. Again though your motor is likely causeing extensive strain on the resistor cuasing it to burn up the resistor. Make sure you dont have any debris in the blower fan squirrel cage. The motor drops out in about the same area. It is held in the blower case with 3 screw from the bottom. It is locat just below the glove box close to the right kick panel.
