95 S14 5speed swap; speed sensor interchangability
Chaotic_Warlord
Car: Black 5 speed Swapped 1995 240sx
IM doing the 5 speed swap on my 94 S14, the speed sensor plug for the automatic is slightly larger for the speed sensor on the 5 speed that I am putting in (95 S14 MT) and while it's snug on the AT speed sensor its a little lose on the MT speed sensor and falls off.
How important is this plug?
What exactly does it do?
Is it possible for me to swap the assembly from my automatic to the 5 speed?
I already have the automatic speed sensor out of the transmission(took it out when I removed the trans from the car) I need an answer ASAP otherwise I'm just going to switch them out and see if it works or not.A
Modified by Chaotic_Warlord at 10:30 PM 11/27/2006
Chaotic_Warlord
Bump
nightkid86
Car: 97 S14 SE
I assume you are keeping the AT wiring harness? iirc I reused my AT speed sensor in my MT.
Chaotic_Warlord
cool thanks, the FSM doesn't specify any differences between the two.
FDNiss240sx
Car: 1996 Nissan 240sx
nightkid86 wrote:I assume you are keeping the AT wiring harness? iirc I reused my AT speed sensor in my MT.
So a late 95 240sx AT speed sensor should work in a 96 240sx MT?cuz i been looking all over the place for a 5 spd, speed sensor and they only have the AT and i wasn't sure if this is going to fit the 5 spd
young-gunn
sorry for the bump, but I would like to know if there is ANY way to make another speed sensor work? I have a 95 auto one, and a 91 M/T one. Anyway without having to order the M/T sensor and waiting 2 weeks for it?
Chaotic_Warlord
yes the A/T speed sensor works just fine, it's what I have in my car and I haven't had any issues with it, then again I never completed the wiring so I don't know if the ECU would need to see the correct speed sensor to not throw a code.
young-gunn
In my case I am using an S13 transmission... What is the possibility of making this work?
