Ric Foster »
https://forums.nicoclub.com/ric-foster-u189017.html
Fri Aug 12, 2011 1:11 am
Hi guys,
I woulds like opinions here please. This is my daughters car and I am working on it. It originally would lose power then die. It would start back up and get her home after letting it sit for 20 or 30 min. A few months later it died and wouldn't start at all. I towed it to my house. Checked for fuel and spark, both seemed O.K.
Here is a list of what I have replaced so far:
Used engine from same model and year Quest from junk yard. (nice and clean inside engine)
fuel pump - new
fuel pressure regulator - new
mass air flow sensor - used
main computer (ECM) - used
pcv valve - new
spark plugs - new
spark plug wires - new
cap & rotor - new
all vacuum hoses - new
all fan belts - new
all rubber fuel lines - new
I have ran the following tests from the factory service manual and they checked out O.K.
ECM input output test
camshaft position sensor test
mass airflow sensor test
ignition coil test
power transistor test
fuel pump test (electrical) I haven't checked fuel pressure on the new pump yet
closed throttle position switch test
throttle position sensor test
IAC valve-AAC valve test
IAC valve-FICD solenoid valve test
ECM relay, fuel pump relay, IAC relay-FICD relay
I have also cleaned every electrical plug under the hood with a tiny wire brush and lacquer thinner when I had the engine out. then sprayed them with electrical component safe solvent and checked for loose connections and tightened every one.
I put on an extra ground strap from the battery to the chassis and from the engine block to the chassis.
Well, I think that's where I'm at.
Everyone's thoughts on this subject are appreciated.
Thank you - Ric
