Defiant »
https://forums.nicoclub.com/defiant-u43224.html
Fri Oct 27, 2006 1:48 pm
EGRs are just vacuum-actuated valves. The garbage that accumulates in them is about half-again as strong as the mortal holding up the Coliseum. In this situation, use the Good Mechanic's Byword: It Ain't Gonna Get Any More Broke.Try chiseling it out with a worn-out screwdriver. Usually, once you get it started, it gets easier to crumble.Keep in mind the rest of the passages and/or tubing leading up to and away from the valve are likely to be similarly encrusted. Stay patient. Do not let any of it get into the intakes and into the cylinders- shop vac.
