You can see my history of what I have done to the car by searching all posts by aaronl and aaronl2. Mileage was 65K when I bought it, now 87,715. It has been driven only about 200 miles since 2006. I wanted to replace the accumulators and upper links before driving it any more. I bought 4 new tires and the front tires wore badly within 15K miles. I will have to put tires on it to pass Texas safety inspection, one has major tread separation. I had the alignment checked when I noticed the tire wear. (yes, they knew to check when running so the active was active.) I did a search here and determined the cause was most likely the upper links. I bought them but have not installed them. TCS has problems (lights are on). Active works, but is flat with no leaks. I had the transmission flushed with BG system. I flushed the brake fluid when i replaced the pads. All of the fluids and filters have been changed when required, including the differential. I have been having the oil changed every 6 months even if it has not been driven. When I have the oil changed I have them drain and refill the several quarts of transmission fluid that will drain. Idler pulleys are noisy on start up. I was told by the previous owner that he had the valve cover gaskets replaced. I requested the service records from the local dealer......service manager told me there were no records for the VIN number. I showed him the original VIN card. I don't know if he was lying or just lazy.
I replaced: fuel pump, alternator, fan, water pump, belt, starter (used from nico member), front brake rotors, front and rear brake pads, broken wheel studs. All parts were new OEM.
I have the following new OEM parts that I will include with the car if I sell to a NICO member: 2 upper links, 2 tension rod bushings, 8 spark plugs, 2 steering rack boots, seals for steering rack, oil pan gasket & screen, 4 cans of active oil, 2 of the "old" oil filters with the proper socket that fits the filter. notice in the photos that the E brake pedal pad is missing I have it. Sony CD changer doesn't work, ( rubber suspension is rotted like they all do).
I love this car, but my wife demands I sell it. of course she is right.... LOL been sitting in the driveway with a cover on it for 6 years. I would like to get $8K for it, but will take $3.8K.
