95 q45 stalling!! need help please!!
95silverq45
Car: 1995 infiniti q45
i have a 95 q45. when you come to a stop, 2 seconds later it stalls. it only stalls on hard braking. if you brake really slow it won't stall. i have checked everything and i'm beginning to think its the computer but i want to be sure. any help would be appreciated. thanks
96Qowner
Car: 1996 Q45
Probably your Mass Air Flow sensor (MAF). It's tempermental on the Q45.
Search this forum for MAF and check out http://www.Q45.org for instructions on checking the connector and cleaning.
Rex
Car: None
Has the fuel pump ever been replaced and was the filter?Do you hear what sounds like a swarm of bees in your trunk?
5seryan
Car: 1995 Q45t R.I.P.
I have the same problem. but it only happens in cold weather. it also stalls sometimes when im backing up and switch to drive. i talked to someone about this and they had a for explorer who did the same thing. It was the IAC but according to wes those dont fail. i have replaced both my fuel pump and filter recently.
95silverq45
thanks for the info. i cleaned the maf but didn't help. fuel pressure doesn't drop when it stalls either. it only stalls on a hard braking in drive. it won't stall in reverse. i had a lab scope on the injectors, crank sensor, coils, almost every sensor and i can't find a glitch!! i found another site i'll try too, maybe some of you guys can use it too
http://www.nissan-techinfo.com/infiniti
Aus94Q45
Car: 1994 Q45
Cleaning the MAF or its connetor will not remedy the issue. The wires inside the male plug are simply crimped. The crimp fails over time and the wires are loose inside the plug. You must cut it off and install a new plug. Easy to solder the new pins before you push them into the new plug housing. About $20 for the parts from Joe -- always start with the easy stuff! You should give this a try, as even if your connector plug has not failed yet, it will -- ask every one on this board.
nchopp
Aus94Q45 wrote:Cleaning the MAF or its connetor will not remedy the issue. The wires inside the male plug are simply crimped. The crimp fails over time and the wires are loose inside the plug. You must cut it off and install a new plug. Easy to solder the new pins before you push them into the new plug housing. About $20 for the parts from Joe -- always start with the easy stuff! You should give this a try, as even if your connector plug has not failed yet, it will -- ask every one on this board.
Just make sure to plug the connectors in to the right pins.
96Qowner
Car: 1996 Q45
Just a thought ... I vaguely remember something about the transmission ... torque converter locking up? ... Someone had your stalling problem (maybe Evan?) and it went away after he dropped the transmission pan and cleaned the filter.
Anyone else remember this?
[Edit]Searched and found it:
zerothread?id=104129
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
not to say its not possible, but its much less likely on a 94+ due to the addition of a factory external filter...... We think that problem evan listed was due to the trans cooler being clogged.
qship96
Car: 1996 Infiniti Q45
elwesso wrote:not to say its not possible, but its much less likely on a 94+ due to the addition of a factory external filter...... We think that problem evan listed was due to the trans cooler being clogged.
external filter on 99% of 94-96 is of no use as it has not ever been changed and is in bypass mode! amazing owners change the way less restrictive pan screen,yet ignore this filter!
5seryan
I had my pan dropped fairly recently and yet i still get the stalling. but only when its cold. i have also cleaned the maf recently as well.
DougQ45
Car: Q45, porsche 928 S 5 speed
I have had 2 Q's that did this. Check your transmission fluid level...it has to be right on, if it is low, it will stall upon hard braking. Strange but true. Make sure you check the fluid level on a flat surface and run through the gears per the manual.
I had this problem until I cleaned my throttle body.
chinaonnitrous
Car: 2002 Maxima to 2004 Evoloution to 1992 Integra
transmission. Still in lock. Mine does it.......fluid overfilled..................
95silverq45
i want to thank all you guys for the advice. i changed the transmission fluid and filter, blew out the lines and it runs like a dream now. it shifts into gear smoother too. thanks again for all the help !!!
99infinitiq45t
Car: White 1999 InfinitiQ45
8 Cylinder
4.1 Liter
I have a 99 Infiniti q45 and just recently within the past month I have encountered stalling while stopped at red lights, its not everytime that it stalls just sometimes. when it stalls the car will start right back up afterwards. fuel pump was changed just this passed january '11 fuel filter was changed last week but the issue is still reccuring.... PLEASE HELP!!!
