Recently bought a 95 Q45, 150Kmi. Service history is unknown but I think this vehicle has been ignored for ~6mo:
- Engine oil black
- trans fluid brown
- coolant low in overflow tank
- humming fuel pump
- loose inside rear view mirror
- grooved rear brake rotor
- only one key
- light collision repair on right front
- missing right side driving/fog light
- right front power window non-functional
- power antenna broken
- missing Sony CD changer cassette
- missing keyless entry remote
- has Maxima wheels (http://www.transwheel.com/limages/ni46.jpg) instead of Infinity oems.
Things done:
- Engine oil change.
- Duplicate key.
- Wired right front window in place. Someone removed pwr window motor and regulator !
- Took out power antenna unit to fix.
- Buy one of those service manual CDs on eBay. Where else can you get them ?
- Tighten loose inside rear view mirror. How ? No externally visible screws.
- Transmission maintenance.
- Figure out how to repair power antenna. Salvage yard, maybe. What other models have compatible antenna units ?
- Replace fuel pump.
- Differential (transaxle) fluid change.
- Find missing parts (CD cassette, power window parts, keyless entry remote).
- Fix power window in right front door. Salvage yard, maybe.
- Wheels & tires (graduate to 16in or 17in). Will inexpensive (but nice looking) aftermarket wheels be Ok ? http://cgi.ebay.com/ebaymotors...87058 http://www.discounttiredirect....ize=2
I found the following parts at http://infinitipartsusa.com :
Code: Select all
Transmission Service Kit - - Q45, 1995 $ 79.98 Bendix Front Brake Pads - - Q45 1994-1996 $ 54.82 Bendix Rear Brake Pads - - Q45 1994-1996 $ 47.80 Front brake pads - 41000K - Q45 1994-1996 $ 64.49 Rear Brake Pads - 44000K - Q45 1994-2001 $ 56.24 Front brake hardware kit - - Q45 1995-2001 $ 45.70 Rear Brake hardware kit - 44080 - Q45 $ 45.70 Metal-Matrix Front Brake Pads - - Q45 '90-'95 $ 47.27 Fuel Pump - - Q45 1990-1996 $234.99What is in the "brake hardware kit" ? Is this necessary for brake pad replacement ?
What's the difference between the Bendix brake pads, Metal-Matrix, and the 'no-name' ones ? Which of these include the brake pad sensors ?
Any parts other than the fuel pump needed to stop the humming from under the rear deck ?
Additional parts needed but not listed at http://infinitipartsusa.com :
- Brake rotors
- Power antenna unit or replacement plastic rope (toothed band).
- Map light bulbs.
- Driving/fog light units (under the bumper ones).
- Right front door power window motor and regulator.
