Code: Select all
............see IC circuits where a capacitor blocks the voltage applied to measure the resistance from entering the real KS circuits only passing the higher freuency noise and knocks.
An extremely complicated process KS probably the most difficult thing in entire ecu.
Above 4,000 rpm there is not enough time to do the job with 90-93 ecu due to low cpu processor speed so another fail safe guess is engaged by KS and ecu.
My test is to data log advance under 1st gear WOT acceleration and always make sure I have 22>28 degrees [moded ecu] from 4,000>6900-7300 summer or winter and adjust the CAS below 15-16 degrees if I cannot hit 28.........after all in a highway pass 4,000>7300 is what counts and a knock detection can leave you splattered on the front of a semi.
The engineers planned everything except the possibility that owners would redesign the system to avoid maintenance and repair.
Why the CAS has 3 separate system as back up to make sure the car will run they did everything they could to give 6 years and 70k of trouble free driving..................unfortunately US drivers don't rebuild as they should.
