95 q45 kid driven
95q45owner
trying to find a home needs knock sensors and i dont think i am up to the job i think it goes in to limp mode sometimes. when driving 65 speed drops to 45. code comes up knock sensors i have checked the resistance and one is bad
I dont mind doing some work but the plenum looks very intimidating in Sacramento ca area 200k
BCC93QT
Car: 1990 Infiniti Q45
1995 Infiniti Q45
The knock sensors aren't difficult. It is just getting there and having all the hoses readily available to be replaced. Also the plugs, gaskets, and the assortment. This is not just a replace the failed part but more of an overhaul to ensure you don't have to get back under the plenum anytime soon. Really depends on what you want to get out of this car. If you have a separate car tackle the plenum job. Do it right and expect another 200k miles other than suspension. Its a good educational experience to boot.
Keep in mind is it in great shape interior/exterior and something that you see yourself keeping up with? Or is it something you only want a year or two out of and off to the scrap yard.
Skibane
Car: 2000 Q45 AE 110K
Bad knock sensors will reduce engine power somewhat, but they don't suddenly limit your max speed to 45 MPH.
What else is going on?
