Final post on this thread.
I put the new starter in last night using the procedure found at this link -->
zerothread?id=120220 . It went in a lot easier then when I took it out (of course). Works like a champ now.
Other vitals I should mention:
Reman. starter from Napa auto parts: $115.99 final cost after core. I also made sure the new starter matched exactly, very important! You may find a listing for 8 tooth and 10 tooth starter, mine and I suspect most others will be 8 tooth.
Miles on my 1995 Q45: 168,000 (starter should have lasted longer)
tools used: top bolt - 14mm curved box-end wrench (Craftsman - starter & manifold)bot bolt - 14mm socket with 2 - 6" ext with uni-jnt in middle (see link above)
I hope this helps those who might have a similar problem. This site was a great resource for me.
Modified by jelvin at 8:55 AM 7/26/2007
Modified by jelvin at 8:56 AM 7/26/2007
