95 Q45 hesitation and not starting
t_than
Car: 1995 infiniti Q45
HI,
I new to this forum but, I'm having a problem with my 95 Q45 (160,000 miles) starting and accelerating. I've changed the plugs, fuel filter, and gotten the fuel system cleaned. When I start the car sometimes it will not start unless I pump the gas paddle. Also, there are times when the car does not accelerate well and the idle is low. I'm thinking the problem maybe with the fuel pump because I can hear it and I was told that the fuel pumps go bad on these cars. Has anyone else had experience with this same problem? How can I check the fuel pump and are after market fuel pumps ok?
T
Q45tech
No, aftermarket pumps are not ok to use because the pump resistance needs to match the electronic pump speed control module. [which costs much more than pump to replace].
Every V8 car has fuel pumps that fail, many way before 160k and 12 years.
My first car in 1967 ate fuel pumps every year, my next in 1971 every 2 years My 1981 every 3 years......my 90 Q every 7 years seems wonderful to me.
jedi_sol
Car: 1996 Infiniti Q45
Try checking the air filter, it could be really old. Also try cleaning the MAF with MAF cleaner.
http://www.q45.org/maf.html
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
jedi_sol wrote:Try checking the air filter, it could be really old. Also try cleaning the MAF with MAF cleaner.
Or better yet, check the MAF connector, including the wiring first.
t_than
What is the MAF and what cleaner do you recommend?
Rex
Car: None
t_than wrote:What is the MAF and what cleaner do you recommend?
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
if you know the pump is bad, then get a new one from joe!
VJ1
Car: 1994 Q45 Ivory Quartz 1994 Q45 Beige Sand 2009 Nissan Sentra White
Welcome to NICO, Todd. I had a similar issue recently on my 94 and it was the MAF connector that was causing it. Follow the instructions on q45.orgfor cleaning it as a first step to solving your problem.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
VJ1 wrote:I had a similar issue recently on my 94 and it was the MAF connector that was causing it. Follow the instructions on q45.orgfor cleaning it as a first step to solving your problem.
Few MAF sensors go bad unless air filter change intervals are abused, or the filter is non-OEM. Check the connector first, including the wiring. Running change in mid 1994.
Modified by maxnix at 8:53 PM 11/29/2006
jedi_sol
Kragens carries a cleaner specifically made for MAF called "Mass Air Flow cleaner."It's a red bottle.
