I'll tell ya what to do.
The passenger side of the engine under the exhaust manifold is where your starter is.
You'll need to whack it a few times with something solid. (Yes, I'm serious.)
Ideally a broomstick or something along those lines. You can carefully thread it under the exhaust manifold and tap on the body of the starter.
If you're using something made of wood, don't be shy, give it a hearty thump. If using something metal, be a little gentler, and watch out for the positive cable that bolts to the starter.
In a perfect world, you'd have a helper turning the key repeatedly while whacking it. If a helper is not available, just whack it a few times, then go turn the key.
Try this several times and see if the car will start.
This is the oldest starter testing method in the book, and in my opinion the most reliable.
If this successfully gets the starter going, replace your starter.
If not, look elsewhere.
Good luck!
