goody90q45 »
https://forums.nicoclub.com/goody90q45-u31761.html
Mon Nov 29, 2010 9:34 am
1- Is your mileage over about 120-140k? Your probably due for a new fuel pump and possibly a controller (FPCU). The fuel pressure measured after the filter should be 34psi at idle and 44psi at full throttle under load. Could also be injector related.
2- Is the rear end sliding going around corners? Time for new struts and bump stops all around. Tokiko blues are about your only choice at about $80/each.
3- Pulling codes will tell you (us) a lot. The ECU is behind the passenger side kick panel which is held in place by a 10mm nut under a 1" square carpet flap. Instructions for pulling codes can be found searching Nico or in the Tech Help section at Q45.org. I'm going to guess there's problems with an injector or two. Look for the directions on ohm testing injectors while your at Q45.org and check them and the knock sensors.
4- Each of the 4 speakers in the Bose system has an amp. It sounds like at least 3 of yours are shot. It's a very common problem. You can reach in through the trunk and unplug the rears very easily. The door panel will need to be removed to get to the fronts. I have used amps for sale in the parts forum.
All your problems are very common to the 15-20 year old Q45 and all are easily repairable. Read all the sticky threads at the top of this forum and do the same at Q45.org to help educate yourself on how the Q works. It will all start making sense pretty quick. With some basic maintenance you can have yours running great.
Welcome to NICO.
