95 q45 front suspension
jamesmost
Car: "95Qmodded, Benz wagon 4matic , 1986 MB 560sec
hello once again, every time i am here it is because of a capital expenditure!!!!! just finished my motor mount job along with a rebuilt power steering pump and other bs here and there.With that said i still have front end noise and also noticed that i have a larger gap in one wheel well. as well front end noise.
Just ordered 4 new tokiko's and a set of eibach springs. i already replaced upper control arms what else do u think i am going to have to replace once we get in therethanksjames
Q451990
Make sure you replace all of the associated rubber parts with the springs and shocks. (Bump Stops, Boots, etc)
Heath
Q45tech
Is the gap differential there with the standard weight driver [160 pounds] sitting in the drivers seat?
jamesmost
i weigh 225 and yes the gap is still larger considerably
Jeff Williams
Car: 1994 Infiniti Q45t
2000 Infiniti I30t
2004 Infiniti M45
71, 72, 73, 82 & 2000 Corvettes
Check the Tension Rods. They are filled with some gel, like the motor mounts, so it should be easy to see if they are leaking. Mine were cracked, and gooey, on the Silver car. I have not checked, but went ahead and ordered new ones, for the Black car. Another source for clunking, is the sway bar. the bushings are about $30, from Joe
jamesmost
thnks jwi have already replaced the tension bars with adjustable ones from stillen (solid no fluid)as well just replaced motor mountsas well i replaced the sway bar bushings with silicone
Q45tech
Measure the weight on each wheel and individual spring stiffness at compression. Only two things that can change ride height.
If springs are accurate within +- 3% a 16" free spring compressed to 8" with 146 lb/inch [total 1168 pounds of load]front spring means a +- 0.25" ride height variation.
Back to 225 pound driver, thats 65 pounds over design weight so roughly 32 pounds split between front and rear springs 32/146= 0.22 inches on left front; 0.26" on left rear spring. Actually a little less since some weight [about 15-20%] is transfer to otherside.
Jeff Williams
2000 Infiniti I30t
2004 Infiniti M45
If the Infiniti springs are variable rate (and I think the are), then, the height difference could be even less than what Dennis says.
-This coming from a 250# driver.
I would check the adjustment on the tension rods, and look at the sway bar, as well. If you have one side adjusted a little tighter, it could be transferring some load to the opposite side, and messing up your ride height.
Was the adjustable tension rods worth it? I have always thought the factory ones resistes twisting, and helped with cornering on rough surfaces. I have almost bought them, on several occasions, myself.
The best thing, I think, would be to put the car on 4 separate scales, and adjust the tension rods and sway bar, to achieve the perfect balance of weight, with the driver in. Of course, after you install the Eibachs, Tokikos, and dust boots.
I know, because I used to be the same weight as my driver, and "He was to valuable to sit in the driver's seat for 8 to 10 hours, while we set-up the race car" Usually it was the last 8 hours before we left for the race track. The good thing was, once we got the Caster/Camber set, I could sleep in the car, unless some smarta$$ kept banging on the car, and we had several, on the race team.
You know, the dust boots have built-in bump stops. Mine, on the Silver car were shot, completely. This could be affecting the ride hight, I think.
