GseaQ wrote:I did check the MAF connector and wires afterwards today. It's tight and won't even really wiggle when I try. I also tugged on all the wires coming out of the connector, but the engine did not falter. There is a bigger green wire (4th wire) from the connector to a plenum bolt that looks like a modified ground, but, no matter, it is also solid.
I have to get either ECUTalk or NDS set up so I can see if there's a code to go with the CEL.
Well, first a correction. The green wire is not from the MAF connector, but from the harness with the other 3 wires going to the MAF connector. It does ground to a plenum bolt, though.
I got Nissan Data Scan set up today and when I started the car after sitting for about 3 hours, it stumbled and stalled while showing the CEL. I restarted the engine being careful not to turn the key OFF before doing so. When I plugged in NDS I got a code 12 "airflow meter circuit" I think it said.
I cleared the code and wiggled, pulled and twisted the MAF sensor plug and nothing happened. The engine stayed smooth and no new code. I even tried tapping on top of the MAf and still nothing happened.
One more thing, I tried to figure out the IAC valve adjustment with NDS. There were 2 "gauges" on the NDS screen for "Duty Cycle" and "AAC Valve". The Duty Cycle reading was 1.32-1.40 and the AAC Valve was 8. Also, the timing display showed 45. Is it 30 that we have to subtract to get the true number? Do I need to make an adjustment to the IAC Valve?
Any thoughts as to what to look at next? All suggestions appreciated.
Thanks guys,Glenn
