DrewQ45 »
https://forums.nicoclub.com/drewq45-u2328.html
Fri Jun 23, 2006 7:42 am
I just posted in Online Mechanic forum...
Alternator replacement should be done from underneath the car. Going from up top is maddening. The "air pump" is your AC compressor.
"If you plan on doing the work yourself, the easiest way is to remove the passenger side tension rod, drop the AC compressor with lines still attached (it sits below the alternator) and that should give you barely enough room to manuever. "
Jesda... there you go with that ten minutes again. The Q clock replacement took you like what, 5 mins? I'm calling Guinesses for your a$$.
