95' Q45 aftermarket brake pads?
93RPS13
Car: Cars, Girls, Cars, Food
what are some good Q45 aftermarket brake pads, you know with less amount of brake dust as possible? Thanks
Less brake dust is not always a good thing.
Metal Master seems to be the preferred aftermarket pad. I've been wanting to try the EBC "green" pads as well.
pimpingurz
i think u should be looking for less squealing. not trying to be sarcastic. i went with the low brake dust and man u could NOT believe the headaches. Metal Master is what i have, works great. no squealing
93RPS13
o ok, ebc one are for the 97 model are they interchangable between 95 and 95? thanks
93RPS13
does any one know if the q45 fit under like 99 G20 rims
90Q45blue
Car: 2006 Honda Accord EX-L
I suggest using OEM pads for the least amount of squeaking. Also, they work better since they are developed specifically for that vehicle. I remember Dennis saying police officers went back to OEM pads on their Crown Vics because they worked the best.
Nick
szh
Car: 2018 Tesla Model 3.
I used OEM pads on cross-drilled, slotted Bradi rotors (from irotors.com) with excellent results! Note that current model from irotors.com may not be Bradi or Brembo.
Z
Simmsled
Car: TSI GTI - E46 325i
The 99 G20 stock front brake setup is the same as the 93-01 Altima setup. 4 lug bolt pattern.
Q45tech
The only [most significant one] downside to the front metal masters is that with drilled rotors you may get some stick/slip groaning at the final stop or first release.
The oem rear pads are the best out there!!!!!!!!!!! bar none.
Make sure what ever pad you get has a FF edge code minimum.....the oem are FE so they fade easier [require more foot pressure] in hot conditions.
93RPS13
Simmsled wrote:The 99 G20 stock front brake setup is the same as the 93-01 Altima setup. 4 lug bolt pattern.
i know that theu have the same bolt pattern but i am worry about the offset
Kinesthesia
Where is a good place to buy Metal Master (or other aftermarket) pads ?
Thanks
Q45tech
Find a shop that does business with World Pac...........they are around $30 delivered to the shop for MM front Q pads.
These are not ideal pads for those of you that live in Northern US as the cold friction leaves a lot to be desired in WINTER.....the oem pads are your best choice there.
Sliding/rolling thru that first stop sign of the day is not a good way to start your drive!
pimpingurz
Kinesthesia wrote:Where is a good place to buy Metal Master (or other aftermarket) pads ?
Thanks
ebay will have some or go to local shop.
edit:
i bought mine at pepboys. i saw some on ebay last week.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Thanks
Joe, of course.
I got mine from Joe - Under $40.
Kinesthesia
Ok, I'll bite... who's Joe ?
Rex
Car: None
Joe at infinitipartsusa.com (NICO sponsor) he hooks us all up. :D
