mpoyner »
https://forums.nicoclub.com/mpoyner-u8903.html
Wed Jun 16, 2004 4:28 am
Background: I have just had to replace the engine in my Q. It had a serious oil leak when I bought it and I didn't know at first because I changed the oil every 1,000 miles for the first 3K miles I put on it. I have since put only 3K more miles on it, for a total of 6K since I bought the car. Unfortunately, I did not keep close tabs on the oil level and learned a hard lesson.
The new engine only has 70K miles on it and runs a good bit stronger than the old engine did when I bought it. It was apparently off of another Active model, because my mechanic said that everything bolted on and all wires, active pump, etc. matched up the same as it did with the old engine.
So, my Active light is on now. He said that I needed to give it time to bleed the air out of the system and add in a little more of the fluid. I am worried about it, though.
Symptoms: 1. When I start the car, there is an audible thumping sound from the left front tire area. Not loud, but I hear it. 2. The active light stays on at all times. The car does not raise up at all, as it normally does when you start up an Active model. 3. Switching the normal and high settings makes no noticeable changes in height.4. The ride is fairly rough, but seems to have become less so since I got it back about two weeks ago.
After performing a search on this board today, I've found directions on how to perform a code search. I will try that tonight and post results. I also have yet to fill in the final bit of fluid because I wanted to let the lines bleed out so there would be room. I assume it's been long enough now that the air should be cleared?
I bought the fluid from Joe in Scottsdale and he said to buy 3 units of it because the system would use 2.5 of them. My mechanic has put in 2. Would it make sense that these symptoms could be simply because of the fluid it still needs?
