95 Q emergency brake light intermittant on and off
jamesmost
Car: "95Qmodded, Benz wagon 4matic , 1986 MB 560sec
my mechanic said it is the float in the master cylinder, not to sweat it. DOES ANYONE KNOW DIFFERENTLY
Q451990
That's probably it. Is your brake fluid filled up to the max line?
Heath
911/Q45
Car: 1990 Infiniti Q45
1996 Porsche Turbo
Sounds fishy. If the fluid is topped off and the ebrake switch is adjusted correctly, I'd consider a bad master cylinder.
jamesmost
what is the scoop on the master cylinder big job? any up grade? my brakes hit fine maby pedal a little low but my pads are 1/3 to 1/2 worn
I had the same problem until a couple nights ago. The floater is stuck due to old icky fluid. You need to flush your brake fluid. Soon as I did a partial flush, the light went away.
jamesmost
synthetic fluid replaced in july
911/Q45
1996 Porsche Turbo
Replace the master cylinder as a complete assembly from Scottsdale. It includes the reservoir and float. About $200.
jamesmost
come on now dont spend my $$ that is comming from someone that spends more than most on his Q added approx 1/8 cup of fluid an wammo no more light maby even less fluid, my screen basket is torn though any fix can i buy just the basket
911/Q45
1996 Porsche Turbo
Several of us mentioned low fluid first. You can buy the strainer separately.
Q451990 wrote:That's probably it. Is your brake fluid filled up to the max line?
Heath
911/Q45 wrote:If the fluid is topped off and the ebrake switch is adjusted correctly, I'd consider a bad master cylinder.
jamesmost
thanks all, weird thing though no leakage level was the sams since i went synthetic in july was just above Min i put it to max
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Hope you didn't use DOT5! Preferred fluid is a good DOT4.
jamesmost
synthetic dot 4 think valvoline
