95 Q check engine light
jamesmost
Car: "95Qmodded, Benz wagon 4matic , 1986 MB 560sec
i guess the check engine icon does not light up but a light above it? if so my check engine lit up for 30 seconds today doing about 60-80 WOT towards red line heard a high level hiss from around the fuel pump then noticed light, i had advanced my timing a few weeks ago and hit fuel cut off a couple of times, do not know if related,
DAEDALUS
Car: 1990 Infiniti Q45
Sounds like one of your LEDs is misplaced. What is the light above the check engine light? Pull the code.
zerothread?id=21144
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Hes referring to the icon... You konw theres the little picture of the engine, and then the light comes on above it... Most cars the icon lights up instead of the light above it like the Q...
jamesmost
what do u think timing advance fuel cut off check engine light it went away quickly
elwesso
2007 BMW M Coupe
If it was only at WOT it wasnt from o2 sensors (injcetor leak)..
Was it during WOT or after it?
jamesmost
gotta tell you- - - when i turn the car off it resets until i trigger it again the only thing i can think is WOT high demand and high heat my mechanic reminded me that i still have an old O2 sensor that we were not able to remove , not when cold ,,not when hot ; passenger side BTY . was gonna take it down from engine but bolts were frozen solid sooo i have been living with it -- poorest fuel milege - i am a very demanding and the Q gets pushed hard about 4 to 5 hours a day 1.5 each way commute and multiple outings getting mixed use milege 65 o/o highway here it is 13mpg consistent GOTTA love it as well he told me to check my gas cap -- which BTY had a ton of pressure gas fumes when i opened it,, we are gonna see the best way to the O2 sensor - ta da
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Might be getting a new catalytic converter soon, too!
Let it sit with some pentrating oil for a day or two.
jamesmost
i only have 2 cats left the upper ones , i re set the gas cap and drove hard to the office today no check engine must have been all that pressurestill want to get the O2 sensor off
jamesmost
light came back on , checked the gas cap and alot of pressure again
DominickJ30
Car: 1993 Infiniti J30t
There is supposed to be pressure in the gas tank, especially if you are riding on low fuel levels, low fuel mean more fumes. Like someone suggested get some penetrating spray on the 02s and let it sit a couple days.
jamesmost
more than normal pressure going to get at that O2 sensor on Saturday will spray ut up fri night but we worked hard on the sensor torched it etc
DominickJ30
jamesmost wrote:more than normal pressure going to get at that O2 sensor on Saturday will spray ut up fri night but we worked hard on the sensor torched it etc
An easier way to heat it up would be just run the car for a couple minutes.
jamesmost
drove car for 2 hours last time tried to get it off and torched it it is frozen solid i think i have to drop the manifold
DAEDALUS
Heh, I usually hear about how hard it is to get the manifold off. If that's the case you might be SOL till you apply a BFH.
jamesmost
BFH ???? gotta tell u i am not happy about it
