timmack wrote:if your headlights dont normally work with the ignition switch off, thats a 1st for me. ive never seen a car that wouldnt let you turn the lights on with the key out of the ignition. maybe im misunderstanding the post? vodka and oj will do that to a person.
Unless he's coming from the German / Euro world. I've never seen a Nissan that doesn't have power to headlights when the ignition switch is off. VWs, for example, don't have power in that situation.
Your headlights should turn on regardless of key position. Hope this helps.
As far as the existence of a relay, I'm not sure -- I'm hoping one of our WD21 guys will come in here. If I had one, I'd be out there right now looking around for it. I can tell you that my 99.5 def. has a relay, and the other two Nissans I've owned have had them.
