95 pathfinder vg34 build
86merk
Car: 95 nissan pathfinder
Hello out there in pathy land. I am building a vg34, and the question I have is, does anyone know of anyone turboing a 95 pathfinder. I am wondering if the exhaust manifolds from a vg30det will fit on the vg33 heads, and if so how much fab work is need to make custom mounts to work around the turbo. If to much work I will stick with high comp engine, if I can get the turbo to work then I will go with low comp. Another question if I do go turbo will the vg30det harness and ecu work on a pathy or will I have to go with something like megasquirt. Also will the vg30det injectors work in the vg30e intake and fuel rail. Thanks alot for your help on this matter.
