johnadamsii »
https://forums.nicoclub.com/johnadamsii-u31282.html
Wed Aug 03, 2005 9:56 am
ok, the wire color coding on mine was slightly different than you describe, but I was able to see a pattern and do what you recommended. I'll keep an eye on it and post an update in a couple weeks if this seems to have cleared the problem (it's going to be hot this weekend, if it was going to happen, it'd be then).
Details: on my Pathfinder, the 2 white connectors had the following color scheme....Left connector, towards steering wheel - Red/Whi, Bla/Yel, Bla/Whi, Bla/Gre, BluLeft connector, away from steering wheel - 3 white, Bla/Yel,Red, Orange
Right connector, towards steering wheel - Bla/Whi, Whi/Bla,2 Bla/Yel, Bla/BluRight connector, away from steering wheel - 3 white, Bla/Yel,Red, Orange
Noticing a pattern with the connectors that had all 3 white, I took those out of the loop. the truck started, all the electrical seemed fine. So, I'm going to go with that for now.
