adamzan »
https://forums.nicoclub.com/adamzan-u123788.html
Mon Jan 05, 2009 5:48 pm
Hi I have a 95 pathfinder. Mechanically it's mint, the body is decent and frame is solid. Only problem is, I've been chasing this shimmy forever. It didn't do it when I bought it a year ago, and I don't wheel it much if at all.
Things that have been done
- new inner tie rods and Center link- inspected rear trailing arm bushings, they're tight.- new front sway bar links and shocks- 3 sets of tires on 3 different sets of rims all re balanced and rotated (I have a set from my old pathy)-Alignment-wheel bearings inspected and re packed.- new brake pads and rotors- new poly tension rod bushings
I recently drove it on a 400km each way trip and it ran fine and the wheels didn't fall off so I know it's solid. But I'd REALLY like it to be smooth all the time. Here is the tricky part. It doesn't do it all the time, and its not related to specific speed, I guess I only notice it over 60kmh. If its freezing cold its usually fine for the first bit but after like 20 minutes or if i hit some rough roads it starts. Its like a side to side shimmy that comes and goes. It's in the front end for sure as I can feel it in the wheel as well. It makes the truck really tiring to drive too. It has 263,000kms on it.
The other issue I'm having is the cruise control. I tried swapping the cruise computer and the actuator with other known working ones and still nothing. Also I checked the brake pedal switch and it is functional as well. When I turn on the master switch the light comes on on the switch and I can hear a click, but when I try to set it, nothing. The dash light never comes on. If you hold set and turn the master on the dash light blinks. It did this with both modules too.
I'd really appreciate any input!
Thanks!
