95 P/U motor mount replace help
Viking2718
Car: 1995 Nissan SE V6 4x4
I've got a 95 P/U 4WD 3L engine, manual transmission and need to replace the motor mounts. What advice do folks have on getting this done? What needs to be removed to get to the bolts?
thanks.
Desert Rat
Car: 2014 370Z M6 Base Coupe
2017 Frontier 4.0
2007 Dodge Ram 2500 Cummins Quad Cab 4x4
1977 F150 4x4 Shorty BUILT
2008 Boulevard C90T
Previous owner of a bunch of Nissans
Short wrenches and drop wrenches are helpful...
A drop wrench like these:
https://www.amazon.com/5-piece-METRIC-O ... 1AMNM65PJ4
You'll want to loosen both sides before fully removing one. Remove the nuts completely on the side you want to replace and loosen the other side as much as you can. Then use a floor jack and a bock of wood under the oil pan to gently lift....it should lift easily...you should be able to lift the motor enough (a couple inches) to get the old mount out and a new one in, then lower gently on the new mount. An extra set of eyes can be handy. The best way to get at the motor mounts is to go in from the side over the tire (can be handy to remove the tire to give you room to work). If the floppy inner fender stuff is still there between the fender and the frame rail, you'll need to remove that to get at everything. There's not a lot of room to work in there but it's doable.
Be VERY careful lifting on the motor. If anything is binding you can crush your oil pan. With the mounts loose, though it should lift up a couple inches easily. Watch for clearances like the exhaust and the floorboard, fan in the fan shroud, etc.
whomadewho
Car: 1997 Nissan pickup
Desert Rat is totally correct. The only other thing would be to make sure the transmission mount is in good shape.
