95 Nissan maxima clutch slave cylinder
Cspeed89
Car: 95 Nissan maxima
So I've got a 95 Nissan maxima and I think I need to replace the clutch slave cylinder because the pedal doesn't work but I don't know where the slave cylinder is located can anyone shoot me some ideas????
MaximA32
Car: '98 Maxima (RIP)
'04 Maxima - Traded
'06 Mazda 6S- Traded
'15 Altima
The clutch slave is located near the clutch fork. If you remove the air box, you should be able to see it just fine. I would also replace the clutch master if you're doing the slave and the rubber line that goes from the hard line to the slave cylinder since those flex lines have a liner that will collapse on itself from time to time.
You said you "think" you need to replace it, what brings you to that conclusion?
All that being said, welcome to NICO! :wavey:
Cspeed89
My clutch pedal goes to the floor and the piece in the transmission that moves to clutch doesn't seem to be moving enough maybe not enough pressure there are no leaks though and the fluid resivoir Is full im just hopin to be ale to fix the problem with out breaking into the clutch
MaximA32
'04 Maxima - Traded
'15 Altima
Sounds like your assumption was correct. I would definitely replace that flexible clutch line as well since it could be an issue with the line too. You've tried bleeding the line yes? Did the problem just come from no where or is this car new to you?
Cspeed89
Have not tried bleeding it but yeah it just started last night I drove a quarter mile to the store no problems and on my way home it started and yes the car is fairly new to me and was rode hard and put away wet but the fact it popped out of no where makes me think it's it the clutch
