95 nissan 240sx engine and transmission in 92 nissan 240sx car?
dragon_d_85
Car: 92 nissan 240sx coupe and 93 nissan 240sx hatch
I installed a 95 nissan 240sx ka24de engine and transmission in a 93 nissan 240sx car used the 93 nissan 240sx wiring and ecu the only ? i got is the 95 transmission only has the 5th gear postion sensor and the 93 wiring in the car uses both the 4th and 5th gear postion sensors what will happen if i don't use the 4th postion sensor will everything work like it is supose too or will i have the reving problems that i hear about when doing auto to manual swaps if anyone ones anything about this help would be greatly needed thanks
dragon_d_85
has anyone every had that problem or am i the only one that has ever tried it
miketrent20
Car: 1991 Nissan 240sx & 2004 Mazda RX8
As far as I know, you should be fine. I beleive the onlt sensor that really matter is the 5th gear snsor. Good luck with your build.
JKL1031
So does a 94 engine fit in a 95?
compactfean
Car: 89 240sx s13 sr gt3071r 23psi
B14 sentra ser sr20de-t 7psi
daily
Yes a 94 motor will work in a 95. The 4th and 5th gear sensors. Are not needed. They cause your ecu to have different rev limits for each gear.....that's it.
biggie
^And cruise control looks at the 4/5 gear sensors.
But holy thread bump.
compactfean
daily
^ THAT I didn't know....I don't have cruise. As for the 94 into a 95, the transmission wont work because the s14 trans has a whole for the engine speed sensor on the bell housing and s13 doesn't. There was a Guy on here not to long ago that tried drilling the hole for that sensor but I haven't seen an update on his post. The air gap between sensor and flywheel teeth would have to be perfect just like ABS sensors and reluctor wheels......or you could swap bell housing's
