zoso-14 »
https://forums.nicoclub.com/zoso-14-u117760.html
Fri Oct 17, 2008 8:27 am
dude, i have the same problem, mine is a 96 so it has a OBD11, code P1400, anyway the EGRC valve solenoid is under the upper intake manifold. Already replaced mine cost me $320.00 for the solenoid and the 2 gaskets, nissan parts only. Code went away on the first start of the car but as soon as I started it for the second time, the code came back. I erased the code with my scanner and took it to get smog and it failed, the technician said " failed for chk eng. light and drive cycle". Dont know what drive cycle means, I guess have to drive it a while, but the code is still there. dont know what else can it be. It's Non-Op at the moment till I get it fixed.
