I'm afraid I'd probably have to agree with this.loystock wrote:You replaced 2 coil packs? Which cyclinder did you put them into? Have you checked the harness as well as the ground points on the engine frame?
I'm worried that you may have had a problem (short) with the Idle Air Control Valve stepper motor and could have fried the power transistors in the ECU.
