NISTECH »
https://forums.nicoclub.com/nistech-u7581.html
Thu Nov 06, 2003 6:39 pm
1995-96 MAXIMA VQ30 ENGINE TIMING CHAIN NOISE
This bulletin amends NTB96-086 and includes updated Service Information, Parts Information and an updated Service Procedure. Please discard all previous paper copies of NTB96-086.
APPLIED VEHICLE(S):1995-96 Maxima (A32)
APPLIED VIN(S):Vehicles built beforeJN1CA21D*TT159384, JN1CA21D*TT736598 or JN1CA21D*TM417975(depends on production line)
APPLIED DATE(S):Vehicles built before February 2, 1996
SERVICE INFORMATIONA new timing chain tensioner, tensioner gasket and guide are available if a rattle of either several seconds or continuously is heard coming from the area of the timing chain cover when the engine is started after a cold soak.NOTE: This new tensioner, tensioner gasket and guide should be installed as a set whenever repairs are performed on the slack-side guide.
SERVICE PROCEDURE1. Verify the engine noise is coming from behind the timing chain cover area and occurs under the conditions described above.
2. If the noise is verified, remove the timing chain cover and check the upper chain tensioner(s) by pushing down on the upper chain mid-span, noting the ease of deflection:. If the chain feels tight, proceed to step 3.. If the upper chain is loose, check the upper tensioners for sticking or clogged screens. Replace if necessary.
3. Remove the old lower tensioner. Check to make sure the oil feed passage to the chain tensioner is clear:a. Remove the engine oil filter.b. Cover the chain tensioner oil feed hole on the front of the block with a rag to catch any oil that may be blown out of the oil feed passage.c. Apply shop air to the oil filter mounting stud to pressurize the oil system. Once the oil from the passages has cleared, a steady stream of air from the lower chain tensioner oil feed hole should be noted. If not, thoroughly clean the passage and recheck to ensure good oil flow.
NOTE: The oil feed passage must be clear and pass air freely before installing the new tensioner, gasket and guide.
4. Install a new lower timing chain tensioner, tensioner gasket and guide as a set using the parts listed in the Parts Information table below.
NOTE: Do NOT use any gasket sealer on the new tensioner gasket.
5. Install a new engine oil filter
NOTE: It is recommended that the engine oil be changed at this time, as well.
6. Reinstall the timing chain cover.
7. Start the engine and let it idle. This will clear any air from the oil feed passages that was trapped there in step 3c.
8. Stop the engine, allow the vehicle to completely cool down and retest for the noise.
PARTS INFORMATION
DESCRIPTION PART # QUANTITY Tensioner, timing chain 13070-31U03 1 Timing chain slack guide 13091-2YO01 1 Gasket, tensioner, timing 13079-31UOO 1 Oil filter 1S208-9EOOO 1
