luisgofarrill »
https://forums.nicoclub.com/luisgofarrill-u178237.html
Wed Feb 16, 2011 7:11 am
Have you tried to see if you have any codes yet? i would definitely do all the basics, (you may have covered some) oil change, air filter, clean MAF, Throttle Body, IACV, fuel filter, check the strainer on your fuel pump(could be clogged if your tank has s*** in it), and check to see if it's running in limp mode. If the knock sensor code is in, it'll run like crap, but won't give you a code...at least on a 96 I30 it won't. Listen to Tiger, he's pretty good at this stuff.
