'95 Maxima Auto transmission wont go in reverse
memphisrep
Car: infiniti I 30
'95 Maxima/182,000.I noticed that it would shift hard into drive but when driving in stop and go traffic it would shift just fine through the gears.Now it will not go in reverse now but drive does work.What does it sound like?What do I check for and what should I be prepared to spend?
driftingmy240sx
Car: 1996 Nissan 240sx rb25det
sounds like you may need to replace the transmission
nissan_4_life
Car: 2006 nissan sentra 1.8s
check trans coller lines
driftingmy240sx
check the cooler lines for what? this is a fluid pressure failure and/or a mechanical clutch failure, based on the symptoms. i don't understand what the oil cooler lines would have to do with this problem?
