GIJOE69 »
https://forums.nicoclub.com/gijoe69-u8902.html
Mon Oct 26, 2009 2:57 pm
Hello I been having trouble with my S14 KA24DE; Did a complete tune up Cap, Rotor, Plugs, Plug Wires, Coolant Temp Sensor & Fuel Filter.
car starts but bogs down then engine cuts out.
if I spray starting fluid it runs off starting fluid and idles and revs fine;
I even re-wired Kragen Fuel Pump to 12 volts via Relay it runs a little better but once I rev it, engine bogs down and cuts off.
also if I unplug the MAF plug idle is higher. not so sure if it is Fuel Pump crapping out any advice?
Also while engine is running I pulled each spark plug wire off and its sparking also unplugged each fuel injector wiring while its running there is a different also Fuel Pump sounds kinda weird when at the on positionthanks
Modified by GIJOE69 at 6:25 PM 10/26/2009
