Okay so my engine is shaking and smoking, smells like gas. So I unplug each injector and it gets worse but #4 stays the same when unplugged. I buy a brand new injector for #4 injector and it runs fine for a few miles then same issue. I'm getting spark in all spark plug wires. Compression is 180 across. Timing is tdc. Swapped ecu and still the same. Checked voltage on all injector harness and it's at 12-13 volts. Swapped injectors around and it's still just #4 injector?
What else could it be? Any advice or help is greatly appreciated.
