I've been troubleshooting some odd behavior, and would appreciate some direction before I replace anything else.
The car is a 1995 240sx automatic w/ KA24DE @ 140,000mi. Mostly stock, other than an unknown brand air intake, apexi N1 exhaust, coilovers etc.
For a while it was running quite rich, exhibiting very aggressive pressure pops any time the revs dropped, getting poor gas mileage and being a general pig.
The car moved pretty decently above 3000rpm, at low speeds it accelerated slowly no matter the throttle position.
Emissions testing at this time showed very high hydrocarbons at low speed/idle.
Both o2 sensors were replaced, the missing crank sensor added, all fuel injectors replaced, fuel pressure regulator replaced, and several vacuum leaks fixed with new hoses.
This solved the richness, as far as I can tell. No more gas smell, much better mileage.
Acceleration may be slightly better, although still not very enthusiastic at low rpm.
Spinning the tires in the dry on smooth asphalt is unlikely without heavy side loading. Maybe that is normal for this base engine
The latest emissions test was aborted due to nearly constant pressure pops between ca. 2300 - 2700rpm, general unruliness, and the appearance of a check engine light.
On the drive back home from this test from there was one instance of hard acceleration which caused harsh stuttering/bogging, with seemingly random jumping of rpm.
This stuttering has happened a few times before, but it's difficult to reproduce. Maybe 1 in 50 WOT accelerations has this stuttering effect.
A quick look at the ECU showed code 12: air flow circuit meter.
The car idles slightly rough, every few cycles of the firing order includes a misfire / loping and slight shudder.
Removing the MAF plug smoothes the idle considerably, which suggests that the MAF is the culprit and needs replacing.
Agree?
I also cannot identify a few things, maybe you'll recognize them:
Taped to the MAF end of the harness, fuse/resistor on the end of it, looks like there was a shroud over it which is broken.
Same area, before the MAF branch.
