InsanityInc wrote:
The 95+ has worse cams but a better intake manifold.
The reason the cams were changed was to improve low end torque. Running the lower lift cams in conjunction with deleting the secondary butterflies (swirl control device) resulted in a little spunkier off-idle power, to help tote that extra 300lbs better.
Also, much of my research has led me to information stating that the 95+ static compression ratio was just a tad bit higher (9.5:1 as opposed to 9.2:1 in the early DOHC), which would also allow for a bit more response and such.
