95 ka into s13?
bikerskater
Car: 1990 240sx with s13 front end
ive been searching but havent really found anything usefull.
with the 95 can you just use the s13 harness but you have to change the dizzy and thats it or do you have to change intake mani's and some other stuff?
jwk2wf
Car: 95 240sx(totaled) 2000 Audi S4 Biturbo
I'm about to do the same swap. the dizzy has to be changed and the intake from what I've read.
J14cm7
Car: 95 240sx S14 SR20det
Need to post more info. Are just gonna swap a 95 ka into an s13 or.... more ppl will be able to help
bikerskater
ya thats it just the ka i threw 2 rods through mine so..... i just need to know what i need or have to change cause from what i read you only really have to change the dizzy?
so...?
J14cm7
The 95 is still ODBI so you shouldnt have to change it unless the connector is different. The 96 changed to ODBII
bikerskater
well from what i have read is if you use a s13 harness you do because the coil or ignitor chip i believe is called is inside the 95 engine but not on the 91-93's
J14cm7
Makes sense. Sorry ive only worked with S14 stuff on S14s and S13 stuff on S13s good luck with your swap.
bikerskater
its cool thanks for your help anyway
bushido
to swap S14 KA into S13:
-Remove S13 engine, disconnect intake manifold, distributor, and exhaust manifold.
-Install S13 manifolds and distributor onto S14 motor.
The s14 motor is now plug and play.
bikerskater
with what harness s13 or 14? and i thought you didnt have to change intake manis whats diff between them? and the 14 has headers on it so im planning on keeping them
