95 j30 tach fluctuating and sticks
houndog1
Car: 1995 J30
Hey you all, New to Nico.I'm sure this topic has been covered in the past so maybe someone could guide me the past post and suggestions.Topic: Tachometer 1995 J30, fluctuating and sticking. I am a mechanic but not familiar with the J30. I do know the shop manual states that the tach is a 2 wire system involving pins 27&20 to the ECU ,BUT WHAT IS THE FIX IF AT ALL THERE IS ONE ? Thank's Guy's Tom
yodawill2000
Car: 94 Infiniti J30
Is the engine revving up and down with the tach??If not it seems to be a wiring issue.If its literally sticking I would think the tach mech is gummed up.Oh and
Welcome to NICO !!!We will get ya fixed up !!
houndog1
Car: 1995 J30
Yodi, It sometimes revs up and down, and then sticks in the last place it rest, it's not working properly. I can do the fix if someone will give me an idea if there is one. thank you
driverdriver
Car: NICO's longtime resident Canuck!!!
First step is to remove the entire cluster, clean connections and plug in. See if that fixes it.
Instrument cluster replacement is an age related common issue in these cars.
houndog1
Car: 1995 J30
Thanks for the input it looks lik I maybe looking, for another cluster
yodawill2000
As Driver mentioned cleaning ALL the cluster contacts is step one.And a free one at that !!!
You will soon learn this whole car is computer controlled.One loose connector/ground will wreak havoc.
