95 J30 Surging/Hesitation
wade
Car: 95 J-30
After the car is warmed up , once I get to 1700 RPM and any steady speed after that , the car will surge/ Hesitate. It does not do this under acceration.
At first I would get a CEL when crusing on the highway for 30 sec to a min, then it would go off. I checked the ECM and had a EGR code.
After cleaning the EGR tubes no other codes have shown up. I have cleaned the EGR return tubes, done a vac. test on the EGR valve. Cleaned the MAF and throttle bodies including the vac. tubes that come from them. Replaced the PCV valves and cleaned the fittings in the hoses.
I have tested the resistance in all fuel injectors all at 11.9 .
New Air filter and fuel filter.
Tried the Knock sensor bypass just to check , no change.
I have checked all of the harness conectors.
Any Ideas ?
